bank 2 sensor 2 engine code
Old Nov 3, 2007 | 04:52 PM
parkbuilder's Avatar
i have a 97 f150 with the 4.6 engine, and just the other day had my check engine light come on. checked the codes, i forget the code number, but it said something about bank 2 sensor 2. i know its an o2 sensor code, but where would the sensor that is throwing the code be? sorry the info is kind of vauge, but im going on what i can remember.
the check engine light came on early friday morning on my way to work (it was pretty cold out, and came on right as i got off the highway) we checked the codes, cleared them, and the check engine light has not come on since. is this just a fluke because it was cold out, or should i look to replace whats wrong?
Old Nov 3, 2007 | 05:03 PM
JMC's Avatar
JMC
25 Year Member
Wait for it to come back on and then post the code number. FYI bank 2 is on the driver side and the #2 sensor is the rear one that monitors the efficiency of the catalytic converter.
JMC
Old Nov 3, 2007 | 05:12 PM
thanks...
Old Nov 5, 2007 | 12:49 AM
Steve83's Avatar
On all engines: bank 1 contains cylinder #1; bank 2 is the other head. Sensor 1 is upstream, and is used for engine management; sensor 2 is downstream, and is only used to measure catalyst efficiency.
In all those, DOWN is the FRONT (away from the bellhousing).
Old Nov 7, 2007 | 04:57 PM
check engine light came back on this morning on way to work. pulled the codes and this is what i got...
P1000 - obd systems readiness test not complete
P0161 - O2 sensor heater circuit malfunction (bank 2 sensor 2)
hope this better gives the info i was asking about before. any ideas on what the problem is? bad o2 sensor? something else?
Old Nov 7, 2007 | 05:17 PM
JMC's Avatar
JMC
25 Year Member
Unplug the rear driver side 02 sensor and check both the male and female connectors for corrosion. Mine was so bad I had to splice in a new connector. Luckily I have some spare harnesses lying around and I used one from it.
JMC
Old Nov 8, 2007 | 01:39 AM
jmg-in-alaska's Avatar
Why doesn't your picture ever show the 5.4L motor?
Old Nov 8, 2007 | 02:56 AM
Because they don't use the 5.4 in the Mustang.
Old Nov 8, 2007 | 09:38 AM
JMC's Avatar
JMC
25 Year Member
It has the same firing order as the 4.6.
JMC
Old Nov 8, 2007 | 05:51 PM
Exactly.
