changing plugs on 5.4 3v
Originally Posted by glc
There is a link to the video in Stealth's sig - I'm surprised that you haven't seen it if you are a dealer tech.
This video: http://flatratetech.com/index.php?categoryid=12&
Originally Posted by machzer
Hello,
Not sure which video you are referring to but there are two trucks at our dealership right now ,one with the cab off and head pulled and one with 3 plug inserts beginning extracted right now. THis is a serious problem with the new 5.4l and even if you follow the pre plug removal procedures you still have a very high risk of insert( bottom half of plug) broken and seized in the head. By the way both trucks had only about 50K KM on them.
I will check again but now Ford wants you remove and inspect the plugs at
50K Km (can you say never sieze) and replace them at 75K KM. They change those values constantly
Hope this helps
Hope this helps
Originally Posted by corvetteguy
does the 03 5.4 have this problem????
Now, the 03 5.4, depending on casting date for the head, either had the original crappy 4-thread head, which required a lot of care in plug R&R to keep them from blowing out, or they have a full 8 thread hole, in which case it's pretty much bulletproof, as long as reasonable care is used in R&R.
This extended plug is unique to 3V heads only - that in 04+ F150's, new MGT's and new V10's.
Originally Posted by MGDfan
First kill the bolded text, please & thank-you.
Air cleaner says 3V I pretty much have
an easy job replacing the plugs??
The truck KR I want has 108K miles at
a ford dealer, and maybe I should negotiate
him changing plugs before I purchase it.
So if the OK.. OK..
They are due to be changed in any case, even with Ford's retarded chage interval spec.
Good luck.
Originally Posted by jonamond
I cant watch the video it asks for usrname and password
DMAC
There maybe some adjustments to make to your firewall
No, Tumba - review all the posts, the procedure to get past that is already posted. It's not anything wrong.
have it your way
something there has been overlooked
I am talking about the computer firewall glc edit
Got a call from the Ford Tech today at Ricart, they didnt have the TSB tool as recommended for removing broken plugs, so they had to go to 3 other Ford Dealers around to get it... They did and they got my 1st broken plug out. Tomorrow they are going after the other 7 plugs which have been soaking for 2 days now. However I talked to the tech today and they didnt know that breaking them free 1/8 of a turn would allow the pen. solvent to seap into the threads so I had to tell them.
Hopefully that ll fix it. I still dont plan to pay more then I was quoted LOL... We ll see how that goes.
I know exactly what you are talking about - and you have not read the whole thread. The EXACT click sequence to get past that is posted. It has NOTHING to do with ANY firewall or network restrictions.
I'm only gonna call you on something when you are totally talking out your @$$ and when I do and you give me chit, I'm gonna shovel it right back at ya.
EDIT: Madcat, I think it may be time for you to find another dealer - they don't have the tool, they don't know the procedure.........that's just incompetence. It's not like 5.4 3V engines are rare.
Then click on Register Now. When the next screen opens, select videos on the top menu. Go to episode 26 and you're good to go.
