PO300 Code
Old Oct 28, 2007 | 04:55 PM
AnthonyL's Avatar
PO300 Code
Hello, I have a 1998 F150 4.6. Last spring I changed plugs and wires because it was running very rough. This fixed my problem at that time. So my truck has fairly new plugs and wires (Ford Motocraft). I am now getting a check engine light and the code is a PO300. The truck is running fine. I don't feel a misfire. I am told this is a random misfire. The only suggestion I have gotten was the coil packs. Does anyone have and details on this code and how to diagnose so i am not randomly changine parts. Thanks, Anthony
Old Oct 28, 2007 | 05:22 PM
jbrew's Avatar
That's a RMD code = Random Misfire Detected -
1. Wires
2. Plugs
3. Coil Paks
Go thru it in that order and replace/clean components as needed.
Sounds like a coil pak is getting weak , maybe not .. Try pulling the wires and goop some more dielectric grease in there and spray some silicone on the wires to seal them up good. Disconnect the battery first.
Old Oct 28, 2007 | 06:54 PM
NYfordguy's Avatar
Did you run your truck very low on fuel? I did with mine on accident and I got a P0300. Filled her up, cleared code no trouble.
Old Oct 28, 2007 | 07:06 PM
torkum's Avatar
Don't overlook a fuel delivery problem. If you can get to a scanner with mode6 you can see which cylinders are misfiring and their counts.
Old Nov 2, 2007 | 05:56 PM
Cleo's Avatar
P0300
Jbrew... you forgot option 4. Change fuel filter.. It worked for me.
Old Nov 2, 2007 | 07:26 PM
jbrew's Avatar
Thanx , yea , I left a few out - must have been in a hurry
Old Nov 2, 2007 | 07:27 PM
MmmBuckles's Avatar
un hook the battery and let it clear the code. and see if it comes back.
