5.4 Sparkplug Question
Old Oct 27, 2007 | 09:06 PM
rkd's Avatar
rkd
I'm looking at a 2005 F150 with an 5.4.
Do the 05's have the same spark plug thread problem that the earlier ones had?
Old Oct 27, 2007 | 09:07 PM
MGDfan's Avatar
Yes. 04 --> 08... all the same.
Old Oct 27, 2007 | 09:08 PM
rkd's Avatar
rkd
Are the 4.6's less prone to this prob?
Old Oct 27, 2007 | 09:15 PM
MGDfan's Avatar
Yes. The 4.6 uses a 'traditional' plug design.
Old Oct 27, 2007 | 10:48 PM
Octane36's Avatar
From what I understand, the 3-valve heads all have deeper threads that did the 2-valve heads and that fixes the issues with sparkplugs shooting out of the heads.
Old Oct 27, 2007 | 10:54 PM
MGDfan's Avatar
Yes. The problem is now one of retention, as the sleeve/shield is binding, below the seal and threads.
An interesting note - sparkplug blowout can still occur even on conventional plugs with full thread count heads, if intial overtightening, or subsequent and repeated R&R overtightening distorts the threads. Much less common, but not unknown.
Old Oct 28, 2007 | 10:52 PM
rkd's Avatar
rkd
What do you mean the problem is now one of retention?
Old Oct 28, 2007 | 11:55 PM
MGDfan's Avatar
The fact that due to deposit buildup between the bore and the ground shield/sleeve, the plugs are difficult to extract - some to the point of breakage.
You should try to look for the many threads that cover this in excruciating detail - or look at the vid linked in Stealth's sig.
Old Oct 29, 2007 | 12:28 AM
Octane36's Avatar
LOL..Nice. Is that why everyone says you should use anti sieze? Ive read some threads where people suggested using anti-sieze and was curious as to why you would do that (especially when people complain about the plugs loosening up and shooting out of the heads).
Old Oct 29, 2007 | 12:42 AM
MGDfan's Avatar
On the 5.4 3V plugs, the hi-temp nickel anti-sieze is used on that shield mentioned above. In essence, to fill the void and presumably inhibit (or at least defer) the buildup of any more deposits and/or provide a coating that deters adhesion of same, and thus allowing extraction without the associated drama .
That vid explains it well.
Now, on conventional plugs a tiny bit of anti-sieze is preferred on the threads due to the dissimilar metals involved.
Strangely, NO thread anti-sieze application is recommended by Ford on the 3V plugs - and I have not, to date, heard a reason for this that makes any kind of sense to me. So, when I did mine, I followed an expert's advice - who's done many, many plugs, and applied a very small amount on the upper portion of the threads.
