rough-dead idle
Old Oct 26, 2007 | 06:45 PM
jmar73's Avatar
rough-dead idle
i have a 98 f150 with the triton v-8 and it has about 120k miles on it.
after it is not run for a couple days, when started the idle is very rough and low, and will die out. if i step on the gas it will run higher and for a minute or two then it will run normal and idle normal....
is this my injectors going bad.????
Old Oct 26, 2007 | 06:57 PM
jbrew's Avatar
Clean Your MAF Sensor - "slow response"
It could be your IAC - Clean the MAF first -
http://www.fordf150.net/howto/clean-...low-sensor.php
Old Oct 28, 2007 | 01:38 PM
jmar73's Avatar
i clean the MAF, when i opened it up it look pretty clean but i cleaned it anyway.
this did not affect anything, it still starts up and stalls but will run if i step on the gas.... what should i look at now?
Old Oct 28, 2007 | 01:40 PM
jbrew's Avatar
IAC is cleaned ? Do This -
http://www.fordf150.net/howto/throttlebodyclean.php
Old Oct 28, 2007 | 01:47 PM
BigChivas's Avatar
Talking
Hey jmar, I run the 2003 triton v-8 and it occasionally does the same thing. Not like that helps.
Old Oct 29, 2007 | 09:07 AM
ProcompF-150's Avatar
The same thing use to happen to me, def clean the IAC and then try the egr and after that try cleanin the throttle body. Replace the fuel filter too if you havent.
