2000 Mini Van Light Problem
Old Oct 20, 2007 | 01:05 PM
kscountry's Avatar
Unhappy 2000 Mini Van Light Problem
The Van dash lights and head lights dim then go bright. I have checked the alternator, and it is good. Does anyone have any other ideas on what I might be needing to check?
Old Oct 20, 2007 | 01:14 PM
polpilot's Avatar
post in the GD secion if you want help
Old Oct 20, 2007 | 04:04 PM
kscountry's Avatar
Thanks for the info.
Old Oct 20, 2007 | 04:15 PM
Bluegrass's Avatar
If it is a rapid instant type of change in headlite brightness, the alternator regulator could be the cause.
Check with an analog voltmeter accross the battery to see this.
You may see good voltage but a change of a volt or so will cause the lights to react to this.
If you can't see much of a change as the lights changes, then suspect a bad ground at some point.
