5.4 auto vs. 4.6 5 spd
Originally Posted by glc
Torque *and* HP - the 5.4 has a lot more of both, today's automatics are almost as efficient as manuals, and they shift quicker than anyone can with a stick without totally abusing it.
Efficiency-wise - I dunno - the autos (4R70/75/100's) are around 25-30%, whereas the manuals are around 15% driveline loss...
Originally Posted by MGDfan
He asked which was quicker, not faster - ergo--> torque
Originally Posted by Gotts2BMe
thats what i mean. There is less drivetrain loss and another gear to keep it revving in his powerband
Really though - power-to-weight advantage is still in the 5.4's favour for both tq & hp, albeit not by very much. But as GLC said, that auto will out-shift anyone but a real stick-wizard....
Well, from a dig - I'd say the 5.4 would leave a lot better. As you get nearer the top, then the 'Faster 150' effect comes into play, and that poor big block 5.4 stroker is toast !
Power to wieght isn't really the answer at all because an old 5 litre mustang with an auto is a full second and half slower in the 1/4mile than the 5spd version, when both have the same power and weight
The reason I posted this is because I was racing the same truck as mine but he had a 4.6 5 spd and I am 5.4 auto. I don't know if he was stock or not. I put a length and a half on him through first. I have my intake, magnaflow 15749, efans and troyer tunes but I also have heavy *** 32" bfg All terrains.
If you raced the other truck already and know the outcome, why are you asking? Don't you know the answer already?
Originally Posted by SMIGGS
Just one question.
Both stock 2 valves with the same options, both extended cab 4x4 shortbox with 3.55 rear ends . Which is quicker.
An "old" 5 liter Mustang had an older automatic, and they were tuned totally differently from the 5 speed versions.
Torque converters more than make up for the extra gear.
There is no way a tourque converter makes up for an extra gear
If you look at an 03 Mach 1 the auto is 7 tenths slower in the 1/4 mile than the auto. The old super coupe is 9 tenths slower in the 1/4 mile with the auto.
I have also seen "identical" vehicles where the auto is quicker. A stick is very dependent on the driver's skill, an auto takes pretty good care of itself.
For every test you can find where the stick is quicker, I can find at least one where the corollary is true.
Besides, I now know not to argue with GLC's implacable logic
