Starter Grind?
Old Oct 3, 2007 | 09:59 PM
jonamond's Avatar
Exclamation Starter Grind?
this happens rarely but becoming more often.. sometimes when i turn the key the starter will make a grinding noise, as if you where starting it while the engine was on. then i stop cranking and try again and its starts fine.
i recently changed the battery because the old one couldn't hold much of a charge and i was often stuck trying to starting with very low battery power and would rarely get it started.
Could this be why this is happening? or something else?
2004 5.4l f150
Old Oct 4, 2007 | 12:31 AM
bricelittle's Avatar
NOT SHURE ON THE TRUCK
but on the lawnmower when it was grinding half the teeth were gone off the starter
brice
Old Oct 4, 2007 | 12:32 AM
jbrew's Avatar
Tighten the top bolt, then the others - prolly to late
Old Oct 4, 2007 | 12:33 AM
Originally Posted by jbrew
Tighten the top bolt - prolly to late
ouch if that's the case that sucks (is it under warranty??)
Old Oct 18, 2007 | 12:30 AM
buck_7900's Avatar
i have encountered the same problem on my 2000 F-150 5.4L have put 2 new starters and a flywheel in and have seen no longterm results
