Is it the IAC?
Old Sep 30, 2007 | 10:30 PM
SlammaJamma's Avatar
Is it the IAC?
Lately when I start my truck it's got a pretty shaky idle. I started it last night and held it at around 1100 rpm for a second and it started to stumble/miss horribly, let off the gas and the rpm's dropped below 500 then settled around 800 as normal. No cel or anything. Has had a good tune-up over the past 10k miles. I clean the IAC pretty regularly, you think it's the IAC or somethin more serious? I know I should have cleaned the IAC before posting this but I just haven't had time today. I'll do it after school tomorrow and let you know how it goes.
Old Sep 30, 2007 | 10:57 PM
jbrew's Avatar
Sounds like the MAF SJ..
Old Sep 30, 2007 | 11:35 PM
I just cleaned the MAF a couple days ago. Hrmm...
Old Sep 30, 2007 | 11:42 PM
jbrew's Avatar
Mine did that for awhile after installing a new IAC It smoothed out finally after I messed around with the PCV valve and 1/4" Vac lines... I dunno - sometimes when you push those lines into the rubber elbow to far - it will block it off - cut off flow completly.
That's why I fooled with em a bit - thought that may be the problem - it may have been , but I didn't test it for flow , just messed with the lines a little.
Then it ran okay @ idle..
It's possible you broke a wire on the MAF - usually you'll get a check engine light when that happens.
What did you clean it with - you may have left a coating on there.
Old Oct 1, 2007 | 12:18 AM
Just regular MAF cleaner, everything was in tact when I finished. Didn't even take it out the truck. Truck runs fine after it warms up though.
Old Oct 1, 2007 | 12:52 AM
jbrew's Avatar
Really ? Then its your IAC for sure
Old Oct 1, 2007 | 08:38 AM
Thanks amigo
