Lucas Octane Booster
Old Sep 27, 2007 | 12:47 AM
Fifty150's Avatar
Has anyone tried it? Does it work? How does it run in a tuned vehicle? Which tuner? More power? Better mileage?
Old Sep 27, 2007 | 01:01 AM
Faster150's Avatar
make your own for less
http://www.team.net/sol/tech/octane_b.html
Old Sep 27, 2007 | 01:21 AM
bricelittle's Avatar
i guess i will be making a trip to the market
dose it work
Bartak1's Avatar
Meh (at any octane booster)
Old Sep 27, 2007 | 01:23 AM
what
Old Sep 27, 2007 | 01:37 AM
Faster150's Avatar
most octane boosters only give u .2-.3 points octane not really enough to make a difference ur better off buying a gallon of xylene and pouring in ur tank and get 1-2 points out of it
Old Sep 27, 2007 | 02:10 AM
Fifty150's Avatar
Originally Posted by bricelittle
what
I saw on The Dukes of Hazard how they put moonshine into The General Lee. But you won't see me pouring any homemade concoction into my tank any time soon.
Old Sep 27, 2007 | 06:50 AM
MGDfan's Avatar
Most octane boosters:
1. don't work - as indicated, increases are only in fractions of a percent
2. contaminate O2's - a real bad thing
In a pinch - you can try Torco, the only one that works as advertised and is safe.
But - if you have an issue that requires a bump in octane, get the root cause fixed. Don't rely on a "remedy in a bottle".
Some folks here use Torco when @ the strip as a safety measure to ensure any potential detonation ( usually under boost) isn't gonna grenade the engine...
bubba
Old Sep 27, 2007 | 09:15 AM
It's cheaper, safer, and more effective to use higher octane fuel to begin with - if you have a need for higher octane.
Old Sep 27, 2007 | 11:12 AM
malexander52's Avatar
Quality of Gas
Keep on mind the quality of the gas you are using and its additives, including ethanol in that they may actually diminish the proposed increases in octane points these products advertise. Additionally, I believe the rule is in order to achieve MAXIMUM yield from higher ocatane, you need a higher compression ratio.
Old Sep 27, 2007 | 11:51 AM
KRCANUCK's Avatar
I'd rather pour it in my glass and mix it with some Bailey's
Old Sep 27, 2007 | 01:22 PM
i tried makin that once dident turn out good
Old Sep 27, 2007 | 01:50 PM
J_C's Avatar
J_C
I run that stuff in my car all of the time. I'm not sure how much of a difference it makes but it gives me more piece of mind whenever I get into boost..
Old Sep 27, 2007 | 08:58 PM
MGDfan's Avatar
What stuff?
If it's Lucas, stock up on O2's - yer gonna need 'em ....
