Cam phasers
Old Sep 22, 2007 | 02:57 PM
ukjones's Avatar
Cam phasers
Does anybody know what it costs to have cam phasers replaced to eliminate ticking noise on a 5.4L F-150 2004 model?
Old Sep 22, 2007 | 03:05 PM
jimmyv13's Avatar
I had mine done under warranty, it didn't take them long to do it...maybe 2 hours so I can't see it being TOO expensive. I take it the truck is out of warranty?
Old Sep 22, 2007 | 03:07 PM
ukjones's Avatar
Cam Phasers
Yes it is out of warranty but I could get an extended warranty for $1400 but if was going to cost just a couple of hundred then I wasn't going to get it
Old Sep 22, 2007 | 03:08 PM
I just wanted to point out, you refer to a ticking noise, and the fuel injectors make a constant ticking noise at idle. This is normal. The cam phaser noise is more of a knock, it's louder and is generally on one side, most often the passenger side of the engine.
Old Sep 22, 2007 | 03:09 PM
ukjones's Avatar
Cam Phasers
Do you think it is possible to do it yourself? With out special tools?
Old Sep 22, 2007 | 03:11 PM
ukjones's Avatar
It is alot louder than injectors i believe. I have a friend at work with a 05 5.4L I'm going to listen to his on Monday to see if there is a big difference.
Old Sep 22, 2007 | 03:12 PM
Have you done a search on the subject? Should be a lot of info on here. Pay particular attention to anything posted by Quintin, as he is a Ford tech and has done the job.
Old Sep 22, 2007 | 04:51 PM
ONELOWF's Avatar
Here's a recent thread, check the video link provided by torkum:
https://www.f150online.com/forums/sh...d.php?t=299286
Old Sep 22, 2007 | 05:46 PM
jimmyv13's Avatar
Before I had mine done, it sounded like a diesel at idle.
