Clutch needs jamming to floor to start
Hey everybody ---
On a new to me '92 F150 (6 cyl., 5 speed, 120k miles), the clutch pedal needs to be jammed wicked hard down to the bottom in order to override the safety default and allow itself to start.
I noticed the amount of play in the pedal/shaft assembly was excessive, and have been told that it is a pretty common problem. First the bushings go, and then the holes in the bracket get a bit reamed, and that leads to the need to push down so hard to trip the switch.
My mechanic told me a new part from Ford would be pretty expensive (esp. once installed).
Is there a simpler fix for this issue?
And, if not, what of taking out this safety feature altogether by cutting a couple of the wires attached to the module attached to the bracket? Which of those wires are involved, and how would I get a cheap/free wiring diagram for this fine truck?
Thanks for any commentary or advice.
John
John
Which wire, Brice? I only looked down there once, and the truck's not at my house right now, but I remember seeing something like 4-6 or so entering a plastic box attached to the assembly on the gas pedal end of things? Am I missing something? Thanks!
haha i dont know
i dont have any wires my grandpa cut them off 14 sum-odd years ago and he is dead now so i cant help ya but i know he did (i was there)
ask a good friend or maybe someone on this forum but i dont think a mechanic can do it (safety thing) unless you know him!!
Yeah, copy that Brice!!
