motor dies
Old Sep 18, 2007 | 01:25 AM
trixman's Avatar
motor dies
this problem is intermitant. i am driving along at 45 mph and the 4.6 dies. sometimes it will come back on and sometimes it won't. it isn't tossing out a code. it did it this last weekend trying to park at the denny's (15 mph at the most) sometime it will die while sitting at the light. no miss or clue it is going to die. the truck is a 97 f-150, 4.6 auto
Old Sep 18, 2007 | 05:23 AM
keith97xlt's Avatar
so its just shutting off immediately?? no sputtering,hesitattion?? weird noises??. sounds like an electrical problem. check all your main grounds. my old dakota did the same thing. turned out one of the main grounds was corroded.
Old Sep 18, 2007 | 10:32 AM
Steve83's Avatar
It never "tosses out" codes - you have to pull them with a scantool. What's your fuel pressure?
Old Sep 18, 2007 | 03:51 PM
trixman's Avatar
we scanned it for codes and nothing showed up. fuel pressure is good. it just shuts off. no warning. no bumps in the road at all.
Old Sep 19, 2007 | 02:07 AM
Steve83's Avatar
You need to do the diagnosis WHILE it won't crank. Fuel pressure, codes (or at least observe the MIL), spark...
Old Sep 19, 2007 | 10:39 AM
trixman's Avatar
that's just it. it fires right back up. there is no sitting there cranking it. it turns over the first time.
Old Sep 19, 2007 | 09:54 PM
Steve83's Avatar
Sounds like a PATS problem - does that truck have it?
Old Sep 20, 2007 | 06:05 PM
trixman's Avatar
what's PATS?
Old Sep 20, 2007 | 06:32 PM
justusinfla's Avatar
Passive anti-theft system. Mines a 97 and doesn't have it
Old Sep 20, 2007 | 08:44 PM
trixman's Avatar
i don't have the factory security system
Old Sep 21, 2007 | 05:29 AM
keith97xlt's Avatar
my vote still goes to a bad ground or something like that.
Old Sep 21, 2007 | 09:17 AM
trixman's Avatar
i am going to check all that out this weekend.
