Adding New Fuel Pump Wiring
Guys,
I'm about to add my new fuel pump and controller. I want to run heavier wiring from the controller directly to the pump. How does the wire pass through the top of the tank? Is there a way to easily run new wiring through the lid into the tank to the new pump? I would rather not wire it to the small stock wiring if there is a way around it. I have not removed the tank to see how it looks yet. Want to have my setup planned out and ready to go once I remove the tank? Is there an easy way to run heavy wire through the top of the tank directly in to the new pump?
Any one have pictures or anything of what it looks like?
Originally Posted by built54
I dont have a picture on hand, but I drilled out the stock wires going to the basket and installed larger wire. Then I used a gas safe sealer to seal off where air might pass through.
