97' 4.2 v6 Blowing PCM fuse-HELP!!!!
Old Sep 2, 2007 | 07:04 PM
brady484's Avatar
Question 97' 4.2 v6 Blowing PCM fuse-HELP!!!!
Turn the key ON not to start and this fuse(#24) under the hood blows. I have disconnected wire harness going to the PCM module , the harness goingto the interior cab at the firewall. Still the fuse blows. I unhooked all the engine sensors,tps,cts,crank,maf,coil. Still the fuse blows. Does anyone have an idea?????
Old Sep 2, 2007 | 10:01 PM
Quintin's Avatar
Check the upstream O2 sensors. Sometimes the wiring rests on the exhaust and burns through, causing a short to ground.
Old Sep 3, 2007 | 08:38 AM
projectSHO89's Avatar
See this thread and it references: https://www.f150online.com/forums/sh...d.php?t=247760
Steve
Old Sep 3, 2007 | 09:34 PM
brady484's Avatar
Fuse 24 blowing-PCM circuit
I found the wire harness burned or melted the wires on the Right(Passenger)side just on top of EGR pipe. Repaired wires and re-routed the harness and the fuse not blowing and truck running. Thanks for help
Old Sep 4, 2007 | 07:10 AM
Great feedback.
Glad you got it fixed.
Steve
