problem after cleaning throttle body
Old Aug 31, 2007 | 12:41 AM
jhedges15's Avatar
i took off my throttle body tonight to clean it, the egr ports, and the iac. one of the egr ports was completely clogged; i fix it and then put everything back together. i turned the truck on, let it run for about 5 minutes and then took it for a drive. it seemed fine, but then when i got to a little higher rpm, it sounded like there was an exhaust leak coming from right under me. is there something i could have forgotten to do or left unhooked (im pretty sure there isnt though)?
Old Aug 31, 2007 | 01:19 AM
built54's Avatar
maybe the egr tube, the nut on the manifold...
Old Aug 31, 2007 | 01:25 AM
jhedges15's Avatar
where is that? are you talking about the one behind the throttle body?
Old Aug 31, 2007 | 01:26 AM
built54's Avatar
the tube that runs from the egr vavle on the throttle body down to the drivers side manifold, a big nut
Old Aug 31, 2007 | 01:32 AM
jhedges15's Avatar
no, just checked, thats connected
Old Aug 31, 2007 | 05:10 AM
mitch150's Avatar
Experiencing same thing
I changed my intake from a k&n to a volant and about a week later mine has started to do the same thing, sounds like a hiss or very rapid rattle, almost like something is loose somewhere. Can't figure the damn thing out!
Old Aug 31, 2007 | 08:06 AM
Faster150's Avatar
describe this exhast leak sound u speak of?
Old Aug 31, 2007 | 10:54 AM
jhedges15's Avatar
its like mitch150 said, a loud hiss like something is loose somewhere. it sounded like when i tried disconnecting the cats from the manifold and didnt get it completely off, just not as loud
i drove it this morning and it didnt sound as loud as last night
Old Aug 31, 2007 | 11:31 AM
Faster150's Avatar
ohh loud hiss at WOT is normal. ur hearing air rush pass the IAC all the vacume line inlets and there are no more baffles in the intake. also u could be hearing the wind rush across the sharp edges on the throttle plate
Old Aug 31, 2007 | 11:57 AM
jbrew's Avatar
Sonnds like the booster tube is disconnected. Or the PCV line that plugs in directly behind the IAC . It's not visible.
That 90 degree elbow back by the firewall in this pic -
Old Aug 31, 2007 | 12:33 PM
SMIGGS's Avatar
Wouldn't that trip the CEL? The OP didn't mention that so I assume the CEL wasn't triggered.
Old Aug 31, 2007 | 01:22 PM
jbrew's Avatar
It might trip a lean code , but not right away. When the PCM tests and determines fault. It doesn't happen right away in most cases - lean conditions have to fail on two consecutive instances before a MIL is set.
It could take a a couple days or 1-3 drive cycles to satisfy the PCM there is a fault.
In this case , it would be the lean side in the PO170's ..
Old Aug 31, 2007 | 06:00 PM
Faster150's Avatar
lol damn jim u post that pic about 2-3 times a week. lol u should put it in ur sig or something
Old Aug 31, 2007 | 07:14 PM
jbrew's Avatar
Haha - I know , that freaking things popular..
Old Sep 1, 2007 | 07:12 PM
torkum's Avatar
Maybe the new owners of the forum will put brews past posts on autopost when key words popup Then his posting numbers would shoot up like a winning slot machine
