96 5.0L Supercharge?
http://www.mustangsunlimited.com/ite...1=FG218020S+01
here's a pretty nice one.
http://www.mustangsunlimited.com/ite...?T1=1001810+01
this is a better one.
I don't know what config you have but with the right 'lower' intake from 87 to 93 Mustang and room on the passenger side for the throttle body, you could use a Kenne Bell 1500 as long as the pullies will align at the front.
I run one in a car application and getting ready to change out to a new motor using a 2001 Exp motor with the GT 40P heads and a 95 Cobra cam.
The 2000/01 Exp cam pulls pretty well in these motors for truck use but I took it out in favor of the Cobra cam's better upper rpm power to compliment the hi flow heads and the blower.
If you keep the boost below 7 psi, and use an FMU for fuel control, you can use all the stock fuel system equipment, but that's the limit without increasing the fuel capacity..
