How To Change Drs Side Plugs ?
Originally Posted by dallas63
how do you change drs side plugs 2000 ford f150 4.6 . theres a bar above them . thanks jay
It can be done w/o pulling the fuel rail also
Yeah, with 3 u-joints, various extensions and a pool full of patience. I had it rigged up and it looked like a tinker toy setup, got her done though in relatively good time. A good tip may be to use a extension on the plug socket with a pin vs. a ball to make sure it doesn't let go on you. Pulling the fuel rail up as well as disconnecting a bunch of other things in the way will save you time. Take the p/s resevoir out of the way too.
