Too Lean
I took my 98 to auto zone and I had about 8 codes, most of them having to do with the mix being too lean. At idle the engine acts like it is running out of gas, I replaced the EGR, Cleaned the MAF, replaced the fuel and air filters, I don't know where to go next IAC, oxygen? Help me please!
I have the 5.4, I did not write down the exact codes but one was for the IAC valve, two were for the oxygen sensors bank 1 and bank 2 too lean, one was for the mass air flow too lean, and the thing is it actually smells like it is running really rich, I tested the throttle position sensor and it was fine.
I don't think there is codes for the IAC or the MAF directly, you need to go to auto zone and get them read and write them down. It's free.
Reason - certain codes will give good cause for others. Until we know all the codes , it's hard to diagnose..
This system exists to take away most of the guess work, go get the numbers if you want her fixed right
I have code P0401 and P1504 and p1131 401 is insufficient EGR flow, i replaced the EGR valve, now I am going to replace the EGR solenoid. 1504 in an IAC malfunction so I am replacing that, 1131 is one of four that indicate lean. Would the EGR or IAC indicate lean and cause a rough IDLE, or do you think I should try something else? I am replacing these this afternoon so I will msg back and let you know how it goes.
Clean the MAF first , replace the air filter if dirty . Your MAF's prolly BLACK.
Your prolly going to need a DPFE sensor. You HAVE to get that from the dealership , don't buy one from a third party vender. Ford updated these and you need the updated one.
CLEAN that MAF first . Before you touch anything under the hood disconnect the battery , then clean your MAF good .. Reassemble your intake , then reconnect the battery and start.
Heres how you clean your MAF -
http://www.fordf150.net/howto/clean-...low-sensor.php
Your codes will go away except for the PO401, BUT, 401 won't come back until 3 or 4 drivecycles depending on cycle lengths. So when you get another Check Engine Light on - That's what it's going to be most likley.
Replace the DPFE like I described above.
I figured it out. I thought I had a vacuum leak but I couldnt find it. After replacing the EGR valve, The EGR vacuum solenoid, the Idle Air Control, cleaning the MAF, and changing the oil and fuel filter I found the problem. Under the IAC there is a vacuum hose connector with a formed bend in it. There was a rather large hole in it and when I pulled on it I ripped it right off, so the rubber was pretty rotten. I held the hose on there with my hand and the truck purred like a kitten. I now have to get some hose tommorow and make the repair.
That sure sounds like the PCV hose elbow......
