Finished cop install...
Old Aug 18, 2007 | 01:34 PM
jbrew's Avatar
Originally Posted by seidita84t
the motoblues have not given me any problems yet. and with the power issue, of course raising voltage alone might not make a noticable increase in power, but once you re-gap the plugs, you will notice it, it's not a huge gain, but it's something, fuel economy has gone up also btw. only problem with adding voltage, is higher combustion temperatures, though your burning the fuel more efficiantly, the higher comb. temp increases NOX readings, your emissions could be perfect but you'll fail a smog due to the high nox reading.
I hope for your sake it works that way. There's only a LOW volt signal comming from the PCM that your trying to counter.. If you have problems in the future, you can just regap so it will run the way it was engineered to..I don't think it's good to mess with it there. I would gap per service manual fro best results myself.
Old Aug 18, 2007 | 03:13 PM
seidita84t's Avatar
per service manual is fine, when the gap needs to be small due to low voltage, and regardless of what the ecm sends in terms of voltage, does not determine the strength of the spark, the signal sent to the coil is just telling it to fire. How much voltage tha coil itself can generate is what determines spark strength. Anyway, if you keep the gap close, sure, it will work fine, but if you've got the extra voltage to be able to disperse the spark over a larger distance and still have enough energy for the spark to be sufficiant, you will have a more complete burn, making more power. i dont know where you get this idea of "countering" the ecm. wanna explain?
Old Aug 18, 2007 | 03:41 PM
jbrew's Avatar
Why would you set gap that isn't recommended ? I believe it's .52-.56. What do you know that would benefit these motors over service manual procedures? If your getting better performance and MPG's just because your coils include more copper in there windings therefore allowing you to adjust gap out of tolerance - which also adds to MPG's and performance, I'm curios to know how and why..
