4.6L gutless
Old Jul 22, 2007 | 10:25 AM
twintips_17's Avatar
Originally Posted by jbrew
Clean her up on the insides and she'll pure like a kitten .
8-9 MPG Holey Hell man !! Get some O2's for that thing!!
Globals got them cheap ,U need all 4, get the BOSCH -
http://cgi.ebay.com/ebaymotors/NEW-B...mZ160019558243
Clean that TB up good , like said above - ports ,Injector's - everything on the inside. It should look like this on the inside. -
AND, don't forget the MAF sensor and put a fresh air filter in her- heres how to clean the MAF and Throttle Body if you don't know -
http://www.fordf150.net/howto/clean-...low-sensor.php
http://www.fordf150.net/howto/throttlebodyclean.php
Awsome info Jbrew. Im gunado that this next weekend. I have a 170000 and i can tell you it hasn't been done. Maybe its about time.
Old Jul 22, 2007 | 12:48 PM
jbrew's Avatar
There's a little more to it towards getting the MPG's out of her and at the same time enhancing performance - like a fresh set of coil pacs or COP's whatever the case may be , The right plugs (OEM Motorcraft), Intake , Cat back, Under drive pulleys , E- fans and even 4.10's depending on your commute.
Everything has to jive somewhat ..
But For the thread starter , just cleaning her up a bit and replacing the normal ware and tare items that can deprive economy ,performance and overall enjoyability is a good place to start.
Old Jul 22, 2007 | 01:19 PM
BROTHERDAVE's Avatar
25 Year Member
I tried to pull a trailer the other day and could only run like 65MPH and got like 8-9 MPG. .......
what kind of trailer?
if it is a travel trailer and the weight is around 6000# or more, then that mpg is about as good as it gets. a box type trailers has poor areodynamics and will kill power and mpg.
