fuel filter replacement 2003 f-150
Old Jul 12, 2007 | 04:15 PM
summerboating's Avatar
I want to change my fuel filter on my truck. By looking at I have a hairpin clip coming from the fuel tank to the filter. From the filter to the engine I have the clamp that would need the special tool to take off. With the hair pin clip I just have to pinch the sides together to release the pin and seperate from the body correct? With the other side I will need to remove the safety clamp and use the special tool to remove the line correct? Does this sound correct?
Old Jul 12, 2007 | 08:51 PM
keith97xlt's Avatar
is it one of those white hairpin clips??? those unhook easy. my crown vic has those. usually they are both the same type connectors on both inlet and outlet. the special tool one can be a pain. dont forget to relieve the pressure before u start.
Old Jul 12, 2007 | 09:28 PM
It is one of those white hairpin clips on the inlet. When you pull that off does the line come right off or do you have to fanagle it?
Old Jul 12, 2007 | 11:51 PM
keith97xlt's Avatar
pull it straight out, the line will slide right off. i know it looks like a cheap setup that would burst under pressure,but those clips work well.
Old Jul 13, 2007 | 12:00 AM
Andy-jr.'s Avatar
I have a 2002 and I needed the tool to get my fuel filter off. I bought the tool at Advance Auto parts for like $3.00 and it took me all of 5 minutes to change the fuel filter. My filter had the clips that pop up off the line also but then you need the tool to slide down the line to release it from the filter. Good luck .
