10-30w oil
Old Jul 5, 2007 | 10:32 PM
doctorD's Avatar
Originally Posted by kraazie8
i dont like the 5 20 oil seems to light but was looking for what others are running, thanks
Use 5w20. I do, and on occasion, 0w30. Most everyone here is going to recommend you use what the manufacturer recommends.
Old Jul 5, 2007 | 10:37 PM
kraazie8's Avatar
thanks for the quick reply i guess im just old school i have a built amc 360 in my cj7 and all i will run is 20 50 vr1, a bunch of my friends have dirt track modified race cars and again the same 20 50 vr1.
Old Jul 5, 2007 | 10:44 PM
doctorD's Avatar
It's hard to divorce yourself from old school thinking. My first car, second car, third, 4th, 5th, and 6th.....all Castrol 20/50.
The rumor is that you could cause oil starvation to critical parts if you do not use the 5w20 wt. oil.
Old Jul 5, 2007 | 10:50 PM
kraazie8's Avatar
well im gonna go buy all the stuff for the oil change in the am is there any brand or type everyone goes with, i have heard not to switch to synthetics unless it was ran from start, cuz it will cause leaks at seals? idk?
Old Jul 5, 2007 | 11:21 PM
doctorD's Avatar
Bunk.
You can switch to synthetic anytime you want between 3000 and 80,000. They come with a synthetic blend in them anyway. Ford's Motorcraft 5w20 syn. blend is cheap and it's good oil. You can use it. They also now have a fully synthetic 5w20.
I use Royal Purple, Amsoil, Leading Edge, Mobil 1, Redline....whatever is convenient to get or order....all synthetic.
But mostly Amsoil, then RP and Leading Edge.
Old Jul 5, 2007 | 11:39 PM
jbrew's Avatar
Your stuck somewhere back in time. Back when synthetics where harsher and seals where weaker.
1998 Ford updated there seals to handle the harsher synthetics , since that time synthetics have come along way and are milder, more versatile.
You can use the oil anywhere nowadays, it's totally replaced Mercon transmission oil..
Engines run cooler , less friction and better mileage can be had, so why not take advantage of it.
