rough idle
Old Jun 30, 2007 | 11:24 AM
calisonic's Avatar
rough idle
i've got a '93 2wd 5 speed F150 with the 4.9l. it's always had a slightly rough idle and it has been getting progressivly worse. also i've noticed that when you touch the gas pedal, the engine stutters and the rpm's drop a lot for just a split second, then it rev's up fine, like there's a delay in fuel delivery or something. so far iv'e replaced:
fuel filter
plugs,wires,cap,rotor
ignition module
Throttle position sensor
MAP sensor
several bottles of Amsoil injector cleaner
air filter
also sometimes in the mornigs it will die when i go to back up. as soon as you let the clutch out enough to start moving it will start to die, so i push the cluthc back in but it still runs lie it's under too much load and after a few seconds it will die.
the MAP made a slight difference, as did the wires plugs and rotor but it's still doin the same thing.
any help would be greatly appreciated
thanx
Old Jun 30, 2007 | 12:35 PM
Other things to look at are the IAC, EGR, and PCV systems, and for vacuum leaks. Any CEL? Any codes?
Old Jun 30, 2007 | 01:02 PM
calisonic's Avatar
iac tests good EGR is disabled, (runs the same even if i reconnect it) pcv valve is new. CEL only comes on because of the EGR.
Old Jun 30, 2007 | 05:53 PM
calisonic's Avatar
btw is there an idle relearn procedure or something for the TPS?
Old Jul 1, 2007 | 06:18 PM
calisonic's Avatar
also, i noticed that when the TPS is dissconected, the engines idles a little high, but runs perfectly without a miss.
Old Jul 2, 2007 | 08:51 PM
calisonic's Avatar
anyone?
