2001 4.6L Fuel pressure regulator hookup ?
Old Jul 2, 2007 | 05:35 PM
designated driv's Avatar
Can someone tell me how to hook up the vacuum lines from the fuel pressure regulator ? One line goes over to the throttle body - that one is a no brainer.
Then there are three others - a Red, Green and White line.
Assuming Ford stuck with this color coding:
1st question: What color is the line going to the EGR valve ?
2nd question: What color is the line going to the fuel rail on the passenger side ?
That should be enough for me to get this hooked up - 2 out of 3. The White one I am pretty sure goes over to the Vapor Management Sensor on the Firewall of the passenger side.
Or if you are an expert on this - simply explain the hookup to me and I'll be totally grateful for your shared knowledge.
The help is appreciated. Thanks
Rob
Old Jul 2, 2007 | 08:21 PM
Kevin24's Avatar
sorry The only one i remember is the red goes from the TB to the fuel pressure reg if that helps
Old Jul 2, 2007 | 09:19 PM
jbrew's Avatar
Red = runs from behind the battery to the regulator on the fuel rail.
Green = Runs from the EVR below the TPS sensor to the EGR VALVE - it plugs into the top.
White = hooks up to the EVAP on the firewall above the master cylinder
Best pics I got - do you need pics of the battery box where they connect?
The Red line is covered with black line protector - you can see where they all connect here if you look closely.
Anymore questions ? I have more picks if your still unsure..
Those pics are from the 98 and are simular to the 01 - The passenger side of the fuel rail , sorry nothing there but the shrader valve . But if your talking the passenger side of the throttle body elbow on the 2001 Red,Black and White , like this -
