CAT's Split
Old May 30, 2007 | 01:15 PM
jbrew's Avatar
CAT's Split
I just noticed my Cat split and is leaking on the passenger side. I can't afford to redo the exhaust - my cat back system is in great shape!! I was wondering if I could leave my pre-cats in place and cut out both cats out and replace them with regular 2 1/2 exhaust pipe for now. Will that work?
Thanx
Old May 30, 2007 | 01:27 PM
Norm's Avatar
Magnaflow HI-flow cats are cheap.
Old May 30, 2007 | 01:31 PM
jbrew's Avatar
I guess Neal tried those and his didn't last a year - was that just bad luck or are they any good? Has anyone else had good luck with em?
Thanx Norm , I'll check them out - I don't think my motor would be as hard on them as Neals is ..
I just looked - Troyer wants $80 a piece , is that a good price?
Summit has some Dynomax Cats for about $56 , are they any good?
http://store.summitracing.com/partde...5&autoview=sku
The question still stands - I really don't want to buy CAT's yet . I just tried some of that muffler mender sh^t , I highly doubt that's worth a hill of beans...If I by-pass the cats for now , what will I loose , torque maybe..??
Old May 30, 2007 | 04:13 PM
Norm's Avatar
I have seen them for 65 online. Try performancepeddler.com
Old May 30, 2007 | 04:29 PM
JMC's Avatar
JMC
25 Year Member
You can use pipe as a temporary fix. Expect that your truck may set a code for the missing cat.
JMC
Old May 30, 2007 | 05:32 PM
jbrew's Avatar
JMC
Looks like I should of took your advice before and straight piped it behind the forward cat. I was going to do that awhile ago. Neal posted I would loose torque if I did that so
Now I've read that Built54 who has the same year truck as me - he gutted all his lol - he didn't end up throwing any codes .. I think all my cats are trashed - over 200,000 miles on them and there noisey as hell. I pulled the heat sheilds to see if the others were leaking - without the sheilds , there still loud, knocking and rattleing - it's like the damn things are communicating with each other
Old May 30, 2007 | 06:18 PM
Kevin24's Avatar
jbrew,you may have a CEL after you do that.That can be eliminated if it does by installing mil eliminators for the back 02 sensors.I think if you do lose any torque it would be hardly noticable.By cutting the back cats it should not have any adverse effects.With the 2 front cats and your cat back in place you should still have sufficient backpressure
Old May 30, 2007 | 06:31 PM
jbrew's Avatar
No kidding - mil - eliminators ?? never heard of them . How would you get ahold of something like that ? maybe I should look her up ehh..?
Old May 30, 2007 | 06:36 PM
Kevin24's Avatar
not sure on the exact name???mil eliminators,02 sensor eliminators Best bet may be to make a new post if no one else chimes in.I think they hook into the 02s to eliminate a cel
Old May 30, 2007 | 06:39 PM
jbrew's Avatar
Okay thanks , not sure if I 'm going to need them - but thanx for the info
Old May 30, 2007 | 06:56 PM
built54's Avatar
Ive had the magnaflow high flows for 50k miles almost, No problems at all.
Old May 30, 2007 | 06:57 PM
built54's Avatar
You dont need them with high flows.
Old May 30, 2007 | 07:44 PM
jbrew's Avatar
Okay , I guess I'll spring for a couple high flows now - it's going to be a biatch trying to get the heat sheilds back on - what should I do with the forward cats then, should I gut them , cut em out? Do I even need them with the high flows?
Old May 30, 2007 | 08:28 PM
Kevin24's Avatar
jbrew,i think what built54 means is that if you replace your 4 stock cats with 2 high flows you will not get a CEL and do not need eliminators?That is what everyone normally does cut them all out.The high flows eliminate the need for 4.
oh cheack out prices at www.performancepeddler.com
If you are a new customer there submit a reasonable best offer and it should get accepted.No shipping charges and they shipped my stuff very fast.
Old May 30, 2007 | 09:07 PM
F151's Avatar
Aren't the cats part of the emissions system, and therefore warrantied for like 10yrs./100k miles?
