95 302 wont start unless primed
Old May 30, 2007 | 12:40 AM
mnice59's Avatar
95 fuel injected 302 wont start unless primed. it has pressure at the fuel rail. no gauge but shoots 4-5 foot stream when cranking. after pouring gas down the tb it starts and runs fine. it got progressively worse meaning it would start fewer and fewer times unless primed until now it wont start without priming. it runs fine when started. except the power booster for the brakes doesnt hold a vacume and causes a high idle when it hisses. i have a junkyard dog booster replacement but havent installed it yet. have replaced the fuel pump relay. it went 2 days with out a problem (while it was intermitent). doubt orielly will exchange but havent. anybody have an idea?
Old May 30, 2007 | 02:17 AM
Steve83's Avatar
Originally Posted by mnice59
it has pressure at the fuel rail. no gauge...
Get a gauge. How old is the fuel filter?
Old May 31, 2007 | 11:28 AM
mnice59's Avatar
thats a great idea. dont got one. is there a higher psi on start-up? again it runs fine when started. by the way its a 1986 NOT a 95. i have a 95 transport, ooops, i switched the years.
Old May 31, 2007 | 11:38 AM
mnice59's Avatar
about the fuel filter; i changed the one on the bottom of the tank diverter on the left frame rail that is just before the high pressure fuel pump, a couple months ago. there is a fuel bowl that unscrews and has a dounut shaped filter. anyone replacing this beware seating the large o-ring is dificult. is there another?
Steve83's Avatar
Sears sells a good fuel pressure gauge for less than $30, IIRC.
There should be only 1 filter, but it's possible that a previous owner installed both.
