SEAFOAM ?'s
Old May 26, 2007 | 08:43 PM
twintips_17's Avatar
SEAFOAM ?'s
So i have read a lot off posts on the product called seafoam and i finallly founf it in the stores. My questions is there have been several ways to run this through your engine and i was just wandering which way was preferred and yeilded the best results.
zzi have a 98 4.6 with 170,000 and it have never been seafomed
Old May 26, 2007 | 09:17 PM
SlammaJamma's Avatar
Search!
The most direct way is to suck about 8oz. in through your brake-booster line, while the truck is running. Turn the truck off for about 10-15 minutes then start it and drive it like you stole it. (It's gonna be pretty hard to start at first, dont get too scared). Enjoy the smoke.
Old May 26, 2007 | 09:19 PM
theres only one vacume line on the booster right? Will it regulate how fast it sucks it up?
Old May 26, 2007 | 10:27 PM
torkum's Avatar
There is only 1 brake booster vacuum hose. No that hose will not regulate the flow, you have to be very careful with that. I hold the hose at a angle and the Seafoam at an opposite angle to it. The vacuum from the hose is strong enough to pull it out of the can with very little effort.
Old May 26, 2007 | 10:41 PM
akheloce's Avatar
Hey, What a coincidence... I have a 98 4.6 with about 170K on it, and it had never been seafomed. About a week after I did it, got a nice leak in the head gasket. (replacing engine while I'm out of town). Did the Seafoam cause it? who knows, but I'm not risking it again. I wouldn't if I were you especially since it had never been done.
Old May 26, 2007 | 10:52 PM
how long should this take and what should i expect from the engine reactions. Do i shut the truck off right after it gets done and let it sit for a while then go drive it. Thats what i assume
Old May 26, 2007 | 11:06 PM
deapee's Avatar
I wouldn't shut it off...suck it in and leave it run until it stops 'choking' then go drive it. Most of the time you get a check engine light.
Old May 26, 2007 | 11:09 PM
is there anything to watch out for?
Old May 26, 2007 | 11:30 PM
ELVATO's Avatar
Uh, I just followed the direction on the can.
Old May 27, 2007 | 01:23 AM
Ive done it a few times and never got a check engine light. Im not Seafoaming anymore though, not worth the risk for the little gains.
Old May 27, 2007 | 02:47 PM
pjb999@yahoo.co's Avatar
Not sure what the risk is, since it's not dissimilar to running detergent gasoline....just follow directions.
Old May 27, 2007 | 03:39 PM
faawrenchbndr's Avatar
Start engine, allow to warm to operating temp.
Remove brake booster vac line.
Insert line into Seafoam can.
Start allowing the vac line to suck about 1/2 quantity of the can.
Imediately turn engine off.
Let sit 15 minutes.
Start engine and drive in a lower gear, maintain 2-3000 rpm until spoking stops.
You want to let the engine sit to allow the Seafoam to disolve the carbon deposits on pistons and valves.
Old May 27, 2007 | 03:53 PM
|SoCal|Screw's Avatar
I'd be careful.
I ran Seafoam in my Dodge and about a week later I have a Cylinder 2 misfire. I'm not using that stuff ever again.
Old May 27, 2007 | 04:05 PM
in all the threads i seem to see a ton of people that either love it or hate it. whats the over all consenses
Old May 27, 2007 | 05:19 PM
jbrew's Avatar
Yeah , stuffing that SeaWiz down here throat until she just about dies isn't any good for her.
It forces the motor to run in a unfamiliar way (from the norm) - that's when stuff tends to break .
Hell , it only takes a couple hours to manually clean the TB yourself - That's a better way all around
