f150 sputtering or stuttering
Old May 21, 2007 | 08:21 PM
lite n's Avatar
Unhappy f150 sputtering or stuttering
I have an f150 2001 4.6 l crew cab when traveling down the road it wants to stutter and then goes on it almost seems like it is not getting gas but it never dies can some one help please ALSSO I NEED A BOLT FOR MY CALIPER KNOW WHERE ICAN FIND ONE SO ICAN GET RID OF THAT RATTLE
Old May 21, 2007 | 09:09 PM
torkum's Avatar
Do you have a check engine light? Have you done any maintenace in the last year; fuel filter, plugs,, wires, COPs ect..? Sounds like a possible COP going bad. As`for the bolt, I always go to Carquest.
Old May 22, 2007 | 10:18 AM
adamcardona17's Avatar
Glad I found this post. However, what is a COP? Is it a coil pack? I have an '01 4.6 as well. If it is a coil pack, is there a way to test each one so that I don't have to spend $50 per coil? It doesn't do it all the time either however. Thanks for the help.
Old May 29, 2007 | 07:36 AM
Rick1067's Avatar
same problem here
I have a 97 4.6 that will sputter in the first 3 min of driving. After that it runs fine. The check engine light is on for the MAS but have replaced it and cleared code but it keeps coming back. Anyone had these same issues?
Old May 29, 2007 | 12:28 PM
bandit002's Avatar
I have a 1998 f150 4.6 and had a stutter to it and the problem was a tiny crack in the porcelin of the spark plug. I replaced it and problem solved, check that first before coil pack. Just a thought hope it helps.
