Changed altenrtor/ now air bag light is on/need help
Originally Posted by Joe_G
Exact same problem. Anyone know the fix?
You will need to reset the SRS system with the appropriate scan tool. That means a trip to a dealer or and independent shop that has one.
A Snap-On Solus is an example of such a scan tool. The ones under $800 or so won't cut it.
There is no way to reset the SRS system without the scan tool.
Steve
Yup
Steve
Steve
Wow, that kind of sucks. Replace your alternator yourself and still need a trip to the dealer. Sometimes Ford really pisses me off.
So, what creates this situation? I assume the system never loses power unless you disconnect the battery, regardless disconnecting the battery does not cause this issue.
I have to admit, I don't get it.
Mike
Mike
From the shop manual: Once 256 key cycles have been recorded since the concern was last detected, the DTC will automatically be removed from memory.
Start now and you should be done by Christmas.
JMC
JMC
Code 52 is Lost/Low Battery Voltage. The diagnostic monitor looks for batt voltage at connector 209 terminal 14 Red/White wire. If voltage at this terminal is intermittent or lost, monitor will flash code 52. Also check fuse #2 in power distribution box, left side of engine compatment.
Originally Posted by bigcntryf150
i have a 1998 F150. Altenator went out. i changed it and now the air bag light is flashing 5 2 code. need help any suggestions.
JMC
