power steering problems
Old May 19, 2007 | 09:41 AM
saxet666's Avatar
ok, its been a while since i posted. so long in fact i had to re-register, been traveling alot. anyway. have been having a problem with my power steering. when i first start up, it feels slow and stiff through the steering wheel. i have no leak, already checked. my question is, how difficult is it to replace the unit? or is it easier to replace certain parts and what are they?
Old May 19, 2007 | 11:30 AM
keith97xlt's Avatar
check your front end. make sure everything is greased and lubed up properly.check basics before start throwing parts at it. you said no leak .did you check the fluid level itself??
Old May 19, 2007 | 12:36 PM
saxet666's Avatar
fluid good
checked fluid level right off when i first noticed the prob. didn't need any then and have never had to add any since i bought it 2+ years ago.
what exactly do i need to check on my front end? i'm handy but not a pro.
Old May 19, 2007 | 01:28 PM
keith97xlt's Avatar
every moving part. tie rod, ball joints etc.... pick up a hanynes manual it has all that info.
Old Jun 27, 2007 | 09:43 AM
wilthis's Avatar
The problem is the intermediate shaft. Its between the steering box and the main shaft. Mine does the same. Part is back ordered forever!
And expensive!
Old Jun 27, 2007 | 10:14 AM
doctorD's Avatar
change the fluid too
I had a service manager tell me that the steering fluid is neglected too. He advised changing it every 45-50K miles because it is susceptible to moisture.
I paid them to go ahead and change mine out using the Amsoil synthetic ATF. The fee was $25.
