Engine sticks at low RPM
Old May 17, 2007 | 06:34 PM
arizonapoet's Avatar
Randomly my F150 5.4 will simply "stick" at a given RPM when driving. Usually it is when I'm at a low RPM and when I try to accelerate it will not. This is very random, and I can sometimes drive for miles working fine and then it will happen. Usually hitting the pedal to the floor a few time will unstick it and will work okay for a time again. Real problem in traffic.
Any suggestions on how I should proceed to fix this one?
Drop me an email if you have a good idea on this,,, appreciate it..
PDH
Old May 17, 2007 | 07:12 PM
F151's Avatar
I would say TPS off the top, but that would surely throw a code................ soooo, who knows??
Old May 19, 2007 | 10:23 PM
Steve83's Avatar
What YEAR is the truck? Is it throttle-by-wire, or is there a real throttle cable attached to the pedal?
Old May 20, 2007 | 08:44 PM
BUZZKILLER's Avatar
If you have a throttle cable, replace it. Mine stuck on me when I was passing someone. The inside of the housing had broken down and was causing it to stick at a certain point.
