P0157 code
Old May 16, 2007 | 11:08 PM
SKRWZ's Avatar
P0157 code
I had a check engine light go on came up with a P0157 code what is that?
I know what code this is but I can't think of it right now
Old May 17, 2007 | 07:09 AM
torkum's Avatar
The code indicates you have a exhaust leak on bank 2 [driver side].
Old May 17, 2007 | 06:25 PM
projectSHO89's Avatar
P0157 is not an implemented code for 96-05 F-series vehicles.
Are you running some kind of tuner, etc?
...or did you, perhaps, transpose digits?
Steve
Old May 17, 2007 | 06:49 PM
jbrew's Avatar
You have an O2 specific code, which is anything below the 170's -
Replace your upstream drivers side O2 - I had this one before on my 98
BTW - You can receive the info here -
http://www.svtlightnings.com/scantoo...tc%20codes.htm
Old May 17, 2007 | 10:42 PM
SKRWZ's Avatar
I thought it was O2 realated, ,,, seems wiered I just put on a 4 new O2's last fall I'll take a closer look at it on the weekend
Old May 18, 2007 | 07:49 AM
Guys, that code is not even implemented in any Ford OBDII system I can find documentation for.
You may be wasting your time chasing a ghost......
Steve
Old May 19, 2007 | 01:28 AM
jbrew's Avatar
I have it in the list Steve ? From that link I posted above
It's a lightning list , but I don't think that matters , does it?
P0145 Heated O2 Sensor Circuit Slow Response (Bank 1, Sensor 3)
P0146 Heated O2 Sensor Circuit No Activity Detected (Bank 1, Sensor 3)
P0147 Heated O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 3)
P0150 Heated O2 Sensor Circuit Malfunction (Bank 2, Sensor 1)
P0151 Heated O2 Sensor Circuit Low Voltage (Bank 2, Sensor 1)
P0152 Heated O2 Sensor Circuit High Voltage (Bank 2, Sensor 1)
P0153 Heated O2 Sensor Circuit Slow Response (Bank 2, Sensor 1)
P0154 Heated O2 Sensor Circuit No Activity Detected (Bank 2, Sensor 1)
P0155 Heated O2 Sensor Heater Circuit Malfunction (Bank 2, Sensor 1)
P0156 Heated O2 Sensor Circuit Malfunction (Bank 2, Sensor 1)
P0157 Heated O2 Sensor Circuit Low Voltage (Bank 2, Sensor 2)
P0158 Heated O2 Sensor Circuit High Voltage (Bank 2, Sensor 2)
P0159 Heated O2 Sensor Circuit Slow Response (Bank 2, Sensor 2)
P0160 Heated O2 Sensor Circuit No Activity Detected (Bank 2, Sensor 2)
P0161 Heated O2 Sensor Heater Circuit Malfunction (Bank 2, Sensor 2)
P0170 Fuel Trim Malfunction (Bank 1)
P0171 System Too Lean (Bank 1)
P0172 System Too Rich (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
P0174 System Too Lean (Bank 2)
P0175 System Too Rich (Bank 2)
I think I know what your talking about tho . On the DVD - that code doesn't exist. I have PO152 and PO154. They only list the sensor 1 fault numbers on disc. Huh , idunno..
Old May 19, 2007 | 06:52 AM
torkum's Avatar
In the Autodata Tech manual it says: PO157- Possible cause - Exhaust leak, wiring short to ground ,HO2S, ECM. To find out what it is a diagnosis has to start somewhere. Listen for a exhaust leak, check the wiring to the O2 sensor, put the truck on a scanner that has mode6 and watch the O2 sensor switch back and forth along with its voltage readings.
Old May 19, 2007 | 07:07 AM
I figure that if a code is not defined in ANY of Ford's documentation including their ODBII system documentation or in the PCED, it was not implemented by Ford.
The above "Lightning" list is of all POSSIBLE OBD-II codes that were defined when the "standard" was defined back in the early 90s and is not actually a list from any Lightning documentation. Just because a fault code was defined didn't obligate the manufacturer to implement it if they chose not to.
Again, what is the source that read this code? Tuners have been noted, especially, for producing erroneous or invalid fault codes.
Steve
Old May 19, 2007 | 01:46 PM
jbrew's Avatar
Nothing @ ALLData.com . This is a vehicle specific code chart for the 98 model year - No 157..
Old May 19, 2007 | 01:53 PM
jbrew's Avatar
Wait a minute , SKRWZ are you sure it's not P1157 ? - Bet it is
Old May 21, 2007 | 09:10 PM
SKRWZ's Avatar
First thaks for everyones help, I had a chance to rescan the truck on the weekend, and I was in a rush when I scanned it last time and wrote it down wrong boy does that make me feel dumb, It is a P1507 code I guess its something with the IAC valve but that was just changed last year,,, sorry for the confusion posting the wrong code
