Got Police Interceptor Engine for 2000 F150
idling
everyone on here that is talking about this idle thing needs to face the facts. The Police Interceptor package does jack****!!! A cop car sitting there idling is terrible for it you are going to get more wear an tear on it idling than on the road. EX. heat is the biggest enemy when idling who cares if it has the police package cooling system unless it is a diesel, gasoline motors are not designed for prolong idling and it does put a TON of wear on the motor. So that motor with 68 grand on it is prob about at the end of its life cycle and there is no way i would take my factory motor out to put in a police motor??? i mean that is like taking a ****ty motor and replacing it with the perfectly fine triton motor which will do anything a "police interceptor motor" will do........
Originally Posted by Aubtigrz2010
Yes, It will have 250hp, infact over 300hp when I buy some of the extra goodies that will be put on. The car came stock with 235, and with the f150's bigger intake it will give it more HP and torque. It will not be stock, it will have a whole lot more power with these PI heads. I can easily get 300 HP out of this motor with a good filter and some headers and some other goodies. I will update when we get the motor In. I have just stripped the intake off the PI motor and am going to Install the F150 intake soon, and other parts, replace a few seals and put her In and get a quick truck.
IF YOUR TRUCK INTAKE FITS, then you have PI heads on your trucks old engine, a NON-PI intake will not fit PI heads... remeber the car intakes' make more HP and the truck intakes' make more TQ due to the intended nature of the vehicles
a guy I know has a 4.6 with: e-fans, decent built tranny, long tubes, free flow exhaust, 30#injectors, ported intake, 75mm throttle body, FIPK, custom tune and he still isn't putting down 300hp
I (and I'm sure others as well) look forward to seeing your dyno results to back up your claims of over 300hp, good luck
HI!... Well after you get the engine installed, go get it dynoed. I think you will be surprised at the HP you "ACTUALLY" get................................
Originally Posted by expy03
To small. By the time you get a 6'2" Officer and equipment, cage, and rear seat, no leg room is left in the rear.
Several agencies have tested vehicles like the BMW, Audi, Volvo, and the like with not very good results. Sure these cars are faster, and may handle better, but they just don't hold up to the abuse. And they are not very comfortable to sit in with a full duty belt.
With the 265HP 3.5 liter next year, it should be a considerably stronger runner than the too-small 3.0
Well, Kind of ran into a problem installing the f150 intake. The heads on the PI engine are bigger than the 97-03 f150s. So the intake for the f150's will not fit. So I'm gonna have to rig up the 02 Crown Vic Intake to work on the f150.
We are going to swap the oil pan to. Exhaust manifold for f150 bolts right on. We are probally going to end up using the Crown Vic Intake and Throttle body and making that work. I just wish I could make that f150 intake fit.
