Truck Is Down
sarcasm or not, your welcome
Wasn't meant that way - I didn't know they changed them in 03. I thought it was the same as the 150 - 04 .
Sincerely thanx
Bonehead
had to reload info into the pcm. truck starts now, but runs rough due to the pcm not expecting the s/c setup. i tried loading my xcall tunes in, but got a "wrong vehicle" message. phone message left at tuners.
So the PCM went brain dead ? Aneurysm ? Your not talking a Flash are yuh ?
Wow !!! This is kinduh of a freak mishap isn't it. There not by chance going to give you any breaks are they - this just doesn't happen , I haven't heard of it any way .
A PCM meltdown yeah , but never a total reload for the same PCM..
Am I missing something here??? This must really suck
What happened?
What happened?
Originally Posted by jbrew
Hey are done with school yet Patrick - Whens the party
What happened?
What happened?
Well It could of been worse - I remeber chipped Ford diesel's where having issue's sort of like yours but worse - The trucks would just die , but they were doing it on the expessway and it would happen @ 70 mph on some occasions -
Hope they get the tune back to yuh fast -
Good Luck..
Good Luck..
UPDATE: i finally got the tune all set yesterday. finally left work with the vehicle after 11 days. got 3/4 of the way home, and the truck shut off at a stop sign. no crank/no start....couldnt even put it in nuetral for the tow truck.
towed back to the shop, and they will look at it later today.
turned out that the ignition fuse blew in the brand new fuse box. tech installed a new fuse, and has been driving around for a good 45 minutes....with no additional problems. HOPEFULLY i am all set now.
Originally Posted by Klitch
if its the same fuse blowing, wouldnt you want to look for the related wires and see if they are shorting out?
todays update...let for work this morning. got about 1/4 from the house...fuse blows. another ride on the wrecker to work. tech went to diagnose...truck started up normal. put it in drive and let it run on the lift for about 30 minutes. truck didnt shut off. never wants to do it when being diagnosed. wtf! i am a lot madder than it appears...i just hide it well.
dude
