How much HP?
Old May 8, 2007 | 10:25 PM
BSL's Avatar
BSL
How much HP?
So here's the deal at the end of the summer I'm getting a completely new exhaust system and I need to know ballpark the flywheel HP I'll be making so I can pick my pipe size, I'm going according to this chart, I think I'll be around 350-400 flywheel hp so I'm thinking 2.25" what are your opinions?
http://www.angelfire.com/my/fan/Exhaust_Pipe_Size.htm
here are the mods I'm going to do (I plan on staying N/A):
EDGE (already have)
Long tube headers
Magnaflow Hi-flow cats
duals X-piped into two 18" maggies
AF1
E-fans
Port and polish stock TB and Elbow
Old May 9, 2007 | 09:43 PM
BSL's Avatar
BSL
Anyone?
Old May 9, 2007 | 10:19 PM
B-Man's Avatar
No way you will be at 350-400 HP, without serious head work / cams or forced induction.
Don't waste money on headers - if you don't substantially increase the airflow into the engine, you don't need headers / exhaust to get it out...
Just my $.02...
Old May 9, 2007 | 10:20 PM
jbrew's Avatar
You might want to talk to Neal about The Magnaflow Hi -Flow Cats. They don't last that long - I think he said he got a year out of them , but that's it ..
I can't remember what he said he uses now , but yeah , sounds like a you gotta good system to me besides that. Anyway, You might want to check it out before you go threw the expense..
Old May 9, 2007 | 10:28 PM
BSL's Avatar
BSL
thanks guys
Old May 10, 2007 | 07:35 AM
MGDfan's Avatar
BSL - check out "Built54's" truck & mods. 265hp to the wheels (which is approx 345 hp crank @ 30% driveline loss). I'm guessing your number's a little high for the mods you stated.
Also - If you push more than 325 hp or so crank, you will need an injector upgrade and a true custom tune to go with it. The stock 19#'ers will be getting maxxed out around that figure. Built did that too.
Old May 10, 2007 | 08:09 AM
Kevin24's Avatar
I also have a suggestion,ditch the Edge for a Xcal 2 so its tuned for your mods.
Old May 10, 2007 | 02:25 PM
BSL's Avatar
BSL
looks like I was a little aggressive estimating what these mods would give, I just used the max #'s I could find for each to make sure I didn't underestimate. Sounds like I should only expect to see 50 extra HP though. Anyways, so headers are a waste of money unless you're blown? thanks for all the replies
Old May 11, 2007 | 01:59 PM
BSL's Avatar
BSL
from troyer website and this is just shorty's, I would imagine long tubes get a little more
"The power gains from these coated headers on a bone-stock 5.4 F-150 average in the 14-17 HP range (slightly more in supercharged 5.4's like Lightnings), and will add even more power as you do other modifications to increase engine power."
so should I get long tubes or not? Because if I do all the exhaust at the same time I'm sure it will save some on labor
Old May 11, 2007 | 02:17 PM
jbrew's Avatar
BSL , I disagree with it being a waste of money - Longtubes will increase horsepower on a bone stock truck . You definitly DO NOT want shorties , that IMO is a waste of money.
Built54 will tell you , I know for a fact that he purchased shorties - went to the dyno and had -0- gains. Then he went with longtubes and gained quite a bit on the dyno - around 20hp.
If you have at least an intake on your truck , add longtubes , flow thru's and a maggie cat back your going to see a noticeable increase in HP .
Trust me , that's a beneficial mod and IMO the best set up
Old May 11, 2007 | 04:13 PM
BSL's Avatar
BSL
thanks jbrew
Old May 12, 2007 | 11:27 AM
Faster150's Avatar
long tubes will definately wake it up!. i made 241HP no tune with shorty headers now ive got a 75mmBBK throttle body and long tubes no EGR or cats and a highflowing muffler. no new numbers im in dier need of a dyno tune. im hoping to be around 250-255rwhp.
Old May 12, 2007 | 03:55 PM
bosox579's Avatar
when i upgraded the exhaust on my truck, i got 2.5 inch pipe and it roars!! i noticed a big difference in pickup off the line and in the mid rpm range down shift. i think 2.5 inch pipe worked out perfect!
Old May 12, 2007 | 06:02 PM
ParkM's Avatar
you should see 30 hp with a good set of long tubes, I'm gonna go ahead and say that you should see 270-280 rwhp with all those mods. You should also dump the Edge and go with a Troyer tuned XCal2. Mike will help you get the most out of your mods.
I just noticed you have a 2V 5.4, your end rwhp will probably be lower: possibly 250 or so...
