3 cylinders misfiring codes
Old May 11, 2007 | 07:17 PM
jbrew's Avatar
COP = Coil Over Plug
Old May 11, 2007 | 07:18 PM
jbrew's Avatar
Just Kidding
Old May 12, 2007 | 02:47 AM
Bluegrass's Avatar
WELL , actually it's 'coil over plug' , there is a link in between but I won't try to change what they are called now.
Old May 12, 2007 | 09:59 PM
jbrew's Avatar
LOL,
DeeBoo, try moving your harness further away from your accumulator - try to do this while it's running bad to see if that changes things.
If you have to drive it in order for the problem to reoccur , use a a clamp to hold the harness further away and take it for a drive.
This was a big prob in the past with the accumulator and wiring harness - if you messed around with it at all , you could have nudged it a little to close to it - this will create havoc on your ignition system.
