v6 to v8 conversion
v6 to v8 conversion
hey i just got a 97 f150 supercab short box 4.2 l but when the engine gets warm it has a knock i got the truck foir an amazing deal so i couldnt say no so i either have to rebuild it or find a new one and its really hard to find a 4.2 cause they are most likely all blown up so what would i have to change to put a 4.6 or 5.4 in it? thanks guys
if your swapping to the 5.4 or 4.6 your gonna want to consider a stronged tranny with it... cleanest way to swap is to change the motor, trans, puter and harness. basically get a donor truck and rape it lol
Your V6 tranny will not bolt up to the v8 engines. FWIW they are both 4R70W transmissions but with different bellhousings. You will need and engine, transmission and wire harness from a v8 truck. If you are going to go forward with the swap find 99+ 5.4 with transmission. The increase in power will put a smile on your face.
JMC
JMC
Add some 50W oil to remove the knock and sell it for a great price (AS is Where is). Then you'll have the money for a 4.6 or 5.4. You should get at least 4k for your truck which will allow you to find an upgrade!
