stripped iac bolts...
I beleive the hose is the source
Page 9!!!!!!!!!!!!!!!!!
Your losing daylight quick unless its in the garage!!!!
make it stop,make it stop
Originally Posted by masonball
i cant tell if the coolant is coming from the hose or from the metal piece sticking out the the tb
- Don't get me laughing, stomach already hurtin - to many situps...
Page 9
We are making a book here .. The Misadventures of Masonball
Just kidding dude , pickin on yuh
It does have a ring to it tho..
Alright now pull your TB, IAC and EGR valve off and clean the ports out of the TB.Do you have any gunsmithing brushes?They work great for cleaning the ports.
Then clean the inside of your TB and the butterfly inside it.For the inside of the TB use some sandpaper,can't remember what grit i used but you want it smooth and brake cleaner to get the anti-sludge chit out.When your done with that lube the inside of the TB with WD-40,Don't forget to clean the elbow also
I repeat no drinks around the computer with this thread
The finger huh
Unless you have a Sippy-Cup - Disclaimer - caution, theres other ways you can loose it -
well i'm done, everything back in its place and clean as hell. I'm just letting the battery drain for a while before I turn it on and try it out. What am I going to do when I start the truck and it still idles like a 1964 that's been underwater?
thanks guys, you stayed with me through over 120 posts.
no, over 130...
no, over 130...
