stripped iac bolts...
Alright , here something to look at
You said something to the effect it ran worse when you replaced the PCV valve so I want you to check this out - it happened to me twice.
The vac lines , the little ones , you should have green, black, red, white 1/4 " lines . If the lines get pushed in to far in the 90 degree elbows , it will cut off the air flow.
The second ring has to be showing - if not , it will not flow.. See the second ring in the pic below ? All your smaller vac lines should have this revealed.
Take a look behind your battery box - theres a bunch there as well . Other than that there all around your throttle body.
Second ring revealed like this -
Battery box area -
BTW - You didn't put diesel or kerosene in the fuel tank be accident did yuh? ( :
Battery box area -
Take a look at all your bigger hoses while the motors running - when a line get soft or you have flow probs , lines/hoses can suck shut and collapse and sometimes pop back into shape when the motors not running - look for line that may have collapse'ed while the truck running - specially around the bends.
Try and reach that 90 that plugs into the back of the manifold while she's running as-well . That one there is the most known for this problem.
Mann, take some more freakin pictures of your engine compartment and post them - or give the link - I might be able to see something that's not right in there..
Or someone else might - pictures help allot..
Ok thats too big sorry
http://i196.photobucket.com/albums/a...0613071219.jpg
http://i196.photobucket.com/albums/a...613071218a.jpg
http://i196.photobucket.com/albums/a...0613071218.jpg
http://i196.photobucket.com/albums/a...613071217c.jpg
http://i196.photobucket.com/albums/a...613071217b.jpg
http://i196.photobucket.com/albums/a...613071217a.jpg
http://i196.photobucket.com/albums/a...0613071217.jpg
Ok guys, I hope these are ok, I took them with my cell phone.
...post #205 of this thread was #204 for me...
What the heck is that thing plugged in into your PCV port? Doesn't look like anything I ever seen ?
Good pics -
Try to stand back a little further and get the entire engine in one pic , when you get a chance - no big deal.
I need time to re- read this thread again - see if I missed something .
What have you done to the truck since you owned it ? and how many miles?
Good pics -
What thing?
Good pics -
What thing?
Good pics -
