determine cyl misfire cause ? 2001 5.4
i have an intermittant problem with a cyl missing... i does not throw a code however there was a service history on number 1 cyl.... i am new to the
F150 club and now i am trying to get a few bugs worked out -- i have a odbII tool but it shows no codes ? i am confused -- any insight would be appreciated 2001 SCrew 5.4 with 80k
Last edited by hayseed; Apr 29, 2007 at 04:58 PM. Reason: change category to engines
It's very very difficult for these computer's to detect that type of failure until the problem worsens.
Therefore, people usually end up taking there vehicles to the dealership and pay a heavy cost for them to pull the necessary info out your comps memory to evaluate, diagnose and fix.
Heres what I would do - First disconnect the battery for 15 minutes then connect. This will wake up the misfire monitor as your computer test's and resets .
Take it for a ride and push your truck to perform (get on it!!) any time you get the chance .
This has been the only way I've been able to set code in with past misfire issue's..
Pushing your motor while the monitors active is your best shot..
I had the same problem and whatever you do, DO NOT PUSH THE ENGINE UNDER MISSFIRE. You could seriously damage ur rods or even a cat.
Ok here is what u do. Remove the COP, Remove the boot. Clean the coil with some fiber optic cleaner and let dry really good. Take a compressor and blow out the spark plug hole (with the spark plug still in) Then take out the plug and wipe it off really good. Its probably covered in oil. If so there is your problem. I always have this problem becuase i broke the screw hole that holds in the coil and now the coil falls out occasionally so water will get trapped inbetween the coil and the sparkplug, thus grounding the spark causing no spark in the cylinder and no ignition of fuel.
make sure everything is clean and reassemble. I hope this helps.
He doesn't know what COP it is. What your telling him to do is a big waste of time at this point .
Anyway, your comp will shut down your injectors before any damage can be done - "limp mode"His COPs failing under a load , pushing the motor while the monitor activated will elevate the problem hopefully enough to run it outside of the default parameters and produce a MIL with a code pending.
Without said light , you won't find it unless you know someone that can mode 6 it for cylinder counts (history) or you run a coil probe thru the firewall and have someone monitor the probe blinks during a drivecycle - you need the tool for that..
These are handy -
thanks all -- actually i do know what a cop is but
i dont know how to take off the little wire connector -- i looked for a tab but i cant see or feel anything ... can someone be specific as to how to remove this little ****** ? i will post when i determine a fix ...
the wire clip/connetor that attaches to the cop ?
i cant seem to figure how to remove the connector that clips on to the cop ?
Hayseed you can try this, start your truck and open the engine lid then pull each of the injector plugs one at a time and listen if the engine starts to stutter. Whichever one you pull and you don't hear the engine shuddering that's the faulty COP.
That usually only works under Primary failure - COP's most of the time fail under certain loads within a drivecycle.
If he had primary failure instead of intermittent , the engine light would be freakin glowin..
COP's just suck
COP's just suck
COP's just suck
Need more information just ask....
Thanks for the compliments smasie
, Yeah, you still can't beat that COP deal on ebay , I know Kevin @ Global Automotive still sells 8 COP's for $96 = $12 a piece AND they have 1 full year warranty to boot!! The dealerships can't come close to that deal.
Yes , if you replace them all at the same time you bring your motor back to life - Handsdown, the very best tune up possible
Here's The Link - http://cgi.ebay.com/ebaymotors/NEW-I...mZ160111254456
, Yeah, you still can't beat that COP deal on ebay , I know Kevin @ Global Automotive still sells 8 COP's for $96 = $12 a piece AND they have 1 full year warranty to boot!! The dealerships can't come close to that deal.Yes , if you replace them all at the same time you bring your motor back to life - Handsdown, the very best tune up possible
Possible COP solution
Coil on Plug Problem and Solution!
Well I think I discovered the solution, quick, easy and cheap. about $4 bucks to give this a try
In Novemeber, I sprayed all COPS with STP wire dryer, It solved the problem for about 2 months,
The next time it acted up, I sprayed just one side very liberally, let it dry, to identify which side had the bad coil It was the passenger side.
I then thought about it, and it seem that the coil on plugs dont nessasarily go bad, water finds it way into the spark plug opening, being trapped and arcing the spark, which is why the check engine light does not come on, the COP is GOOD, it is sending sprak to the plug , just shorting out on the way down to the plug.
There apparently is a pliable gasket at the bottom of the cop to prevent water getting down into the plug recess, when gasket is unlubed, water gets trapped and causes missfire. Thats why sometimes it may go away if you burn it off.
So I sprayed the STP Wire dryer liberally on top of the cops, and around the base. Let dry for an hour, It has entirely solved the problem. Now ok Since January!
I wonder how much Ford dealerships have profited from THIS design flaw when the cops were actually ok?
