Cleaned IAC, what next?
I have the good ol' rough idle in my 03 5.4 auto. Removed and cleaned IAC last night and re-installed. No change in rough idle. Should I spray the MAF or clean the TB next? If all 3 of these don't do it, I'll go on to plugs, wires and cop's.
Explain what you mean by 'rough idle'? Does is fluctuate up and down? Does the truck shake? Give some examples. My truck shakes/vibrates at idle when warmed up. I've replaced COP's, spark plugs, you name it. No luck.
Anthony
Anthony
Anthony
Anthony
Originally Posted by NKENN
If the truck runs fine (except at idle) the first thing I would look for is a vacuum leak. The injectors would be the second thing I would suspect assuming you have good gas in the tank.
Originally Posted by sysman_rick
Have you considered servicing/cleaning the injectors ?You can purchase a service kit that attaches to fuel rail.
Masonball,pull your air intake and then open the throttle.Get a flashlight and look into the TB.If it is filled w/ sludge then remove the TB and elbow from the intake and clean them.Be sure to also clean all of the ports out.Get your gaskets first,i could not find them local so i ordered from ford.I used brake cleaner to get the sludge out and then lubed it up w/ WD-40.If i remember correctly you have relatively low miles like 80,000 correct?
Originally Posted by masonball
Ya - about 76,500 - how'd you remember that? anyway, I can take off the air intake, but do you mean to take it off with the engine on and look in it then? Which gaskets are you talking about?
i remembered from your rear end prob and i remember numbers well. Hell no don't start it,leave it off.There is a TB gasket,Then there is a gasket on your elbow where it bolts to the lower intake.You als need a new EGR gasket.
cleaning that throttle body makes a big difference. did mine last week and its much more responsive and has more pep. it has 130k and runs like new. i couldnt get that egr tube off though. so i couldnt get to the egr ports. didnt have the right size wrench. o well
took me about 20 mins. i didnt take the whole thing off though. i cleaned the throttle plate and the i.a.c ports. the e.g.r ports are what usually needs the most cleaning.i sprayed the cleaner in there but i heard its best to take a small brush and scrub it out. if anyone knows what size wrench that e.g.r. nut is that goes into the throttle bidy met me know. couldnt get a pipe or big adjustable in there.
