96 F150 with 200,000 miles
Old Apr 16, 2007 | 07:46 PM
jparker's Avatar
I have a 96 F150 5.0 with 198,000 miles that does not burn oil and runs great. The engine is as clean as the day I bought it. I have replaced the belt, alternator and pulleys, flushed the tranny and performed regular maint. Any recommendations on if I should replace the plugs or other maintenance that should be done or just leave it alone. I use it 70 miles a day and pull a boat on weekends.
Old Apr 16, 2007 | 08:08 PM
risupercrewman's Avatar
Replace the plugs, & just keep performing regular maintenance, the 5.0 is a great motor, aside from some oil leaks, they will run forever! I had one in my 1989 Mustang LX!
Old Apr 16, 2007 | 09:29 PM
Steve83's Avatar
Follow the regular maintenance schedule religiously. You might find it interesting to send off an oil sample to find out how much longer the bearings & valve guides will last. There are several companies that will do it for $40-200 per sample.
http://www.blackstone-labs.com/gas_sampling.html
http://www.dysonanalysis.com/premiumkits.html
http://www.oaitesting.com./
You can probably find several more on BobIsTheOilGuy.com (BITOG).
