Quick Oil Change Question
Old Apr 17, 2007 | 10:26 PM
chris1450's Avatar
Originally Posted by adrianspeeder
Just as long as ya get the oil in yer good, but cheeze and crackers! Ditch the fram!
Motorcraft all the way...
Adrianspeeder
looks like the FL1A will fit our trucks.. anyone know if that is true? would be nice to have a larger filter.....
Old Apr 17, 2007 | 10:30 PM
chris1450's Avatar
Originally Posted by BlueOvalFitter
Take one of each apart and you'll see!In other words,the FRAM is a POS! Stick with factory Motorcraft and you won't have to come here and ask these questions!
do an online search and the standard fram has half the filtering area that other filters have.. and as was said.. the drainback valve is either non existant or substandard. FWIW... before I knew this I used a fram on my 1985 ranger since I owned it.. It has 280,000 miles, 175,000 that I put on it using nothing but fram. But still.. why chance it when the motorcraft filter is cheaper at walmart.
Old Apr 17, 2007 | 10:43 PM
referee54's Avatar
I don't worry about a few bucks either way when I am changing the oil---what is important is not saving the $$ on the oil but saving $$$ long-term on the truck. I use Motorcraft all th way around. I stick to what the fac specs said.
Tim C.
