2006 5.4 screw hesitating to start
well its the second time its happended when i start my truck it rumbles than stops and it says check gauges then i try again and it struggles to start till it finally starts....has anybody else had this problem....i think its either the fuel filter or fuel pump but i could be wrong so i'm taking it to the dealership tommrrow since i got warranty still...but yeah...anybody know whats up or has had this problem
There are quite a few threads about this issue. Some have had luck getting it fixed; others haven't. If your dealer determines the problem, please post the resolution here.
Here are a few threads to get you started:
Hard to start when warm 5.4L.
05 FX4 hard to start *sometimes*
Truck would not start....
Truck wont start....sometimes
Mine has done this about 5 or six times then it won't do it again for maybe a month or so. I had a 2003 Mach 1 stang and it would do it every so often too. Mine has always started on the second or third try so I haven't worried about it too much. Also it mainly does it on a short trip when it doesn't get good and warm, or if it was warm and sat for about 20 min. but didn't get all the way cool. Hope the dealer gets it fixed for ya, but I'd expect the good ole "Could not duplicate the problem" BS
My 05 periodically does this. I'm thinking it's b/c I don't hold the key long enough(popping the key sorta speak). Either way, I hit the gas pedal once then let it sit for 5-10 seconds. It doesn't hesitate to start after that. I've found it only occurs once or so a month. I'm not having the stealership dissect my machine to TRY to find an answer. If it get to be more common, I might look into it. Can't be the fuel filter on mine, just changed it.
yeah i just finished dropping it off and they told me there if they cant duplicate it they can't change the wiring harness that causing the problem in TSB that they posted and its BS my truck is not even a year old and is still under warranty...AHHH I WANT IT FIXED DAMN IT
I'm thinking that I might go ahead and change out the starter terminal wiring pigtail myself. Anyone have any idea how difficult that job is? I figure it can't be that bad...
FWIW, Ford reflashed my PCM after I reported the problem the first time in Oct 05. This seemed to help for a while, then the problem returned.
My truck 07 s-cab fx4 did the same exact thing once. I just got done playing basketball and hopped in. It fired up and as soon as I let off the key, it died. I was like WTF...sat there for 5 seconds and turned the key again...fired right up and I haven't had a problem since. That was at about 400 miles...I now have 800 or so. I never gave it a second thought.
Have had the same problem in the past with my 06 5.4. It usually happend to me at least once a week. Always once the engine was warm. I could even duplicate this on a regular basis outside the regular F ups from the engine. I got mine fixed with the EDGE.
I even tried to duplicate it after I installed the EDGE and it hasn't happened again. I'm on LVL 2 by the way. I'm convinced that my problem was in the computer program that the ford engineers pulled out of their colective butts. Don't you guys think that it's weird how well these trucks run after putting in a tune? You would think Ford would live up to their reputation. Don't even get me started on the brake rotors. Unfortunately, "Built Ford Tuff" isn't what it used to be folks
