vibration
Old Apr 15, 2007 | 05:02 PM
wallygator's Avatar
vibration
When letting off the gas I get a slight vibration through the drivetrain.I do not feel it thru the steering wheel. Anyone have ideas as to where to start loojing for the problem. Also believe tranny fluid is leaking into the transfer cas as about a month ago I opened to plug to check level and it gushed out/possibly the problem is related?
Old Apr 15, 2007 | 05:12 PM
wallygator's Avatar
vibration
How,brain dead today as most days it appears.Truck is a 97 f150 4.6 off road pkg,automatic,hope that helps ,thanks in advance
Old Apr 16, 2007 | 05:23 AM
TennesseeTritan's Avatar
I would check the u-joints.
Old Apr 16, 2007 | 08:18 AM
Klitch's Avatar
my 97 has a problem of vibrating around 45-50... is it worse for you at that speed or is it whenever you let off?
yes i have heard of the earlier truck like 97's leaking into x-fer case. the seals are probably bad, but the only problem is i cant find out if its really bad or just a nuisance?
how many miles on that bad boy? im thinkin something like torque converter. usually you can hear u-joints.
Old Apr 16, 2007 | 01:34 PM
wallygator's Avatar
114,000 miles on the truck. Had I retired Ford mechanic tell me to put new u-joints in as well. As thats obviously the least expensive option I'll give it a try tommorrrow
Old Apr 16, 2007 | 06:06 PM
Faster150's Avatar
could be TC seal or TC shutter. mine will do it but thats because the computer it trying to lock the converter to use the transbrake it has. and it wont lol so it just shutters. trying to lock itself.
Old Apr 17, 2007 | 03:30 AM
The reason I say u joints is I've been there done that. You couldn't hear mine until later on when they got real bad, but it started off with vibration, usually when lightly getting back into the throttle. This was on a 69 Camaro though, not my truck.
