No Place for the CHT
Old Apr 10, 2007 | 12:29 AM
ONELOWF's Avatar
I'm doing a head swap from non PIs to SVOs, and there is no place to plug in the sensor. I'm sure I will have to tap it, or have a machine shop tap it as it looks to have critical dimensions.
Is there a plan B?
[IMG][/IMG][IMG][/IMG]
Old Apr 10, 2007 | 12:41 AM
Klitch's Avatar
o.O
talk to troyer? i aint seen this before, but i thought there was one sensor that could be deleted via a tune? otherwise yeah, you may want a machine shop to do it to be safe.
Old Apr 10, 2007 | 08:40 AM
ONELOWF's Avatar
Originally Posted by Klitch
o.O
That sounds familiar - I think the 04+ trucks do not have a CHT, but use water temp sensors to " infer " CHT.
Old Apr 10, 2007 | 09:27 AM
jbrew's Avatar
Really ? The Aluminum intakes had both the ECT -
And the CHT - Sensors -
Then the plastic manifolds were introduced without the ECT's - the PCM figured all temps using just the one sensor(CHT)..
So now they switched back to the ECT's again in 04? Can't they make up there mind
Old Apr 10, 2007 | 09:39 PM
torkum's Avatar
Hey jbrew, I think I read that the CHT won't throw a code on a '98 [in the powertrain control manual]. If thats true and its not plugged up will it do anything or will that start shutting injectors down?
Old Apr 10, 2007 | 10:44 PM
ONELOWF's Avatar
I guess not - see link below, third post.
My 98 has two ECTs - one to the PCM, and one to the gauge on the dash, as well as the CHT which at the moment is homeless!
After some more very close looks, I do not see enough material to tap into the casting where the CHT should be located, with out it becoming an ECT, chit!
https://www.f150online.com/forums/sh...ighlight=infer
