tach install
Old Apr 6, 2007 | 01:06 AM
sc98f150's Avatar
tach install
anyone know where the negative d.i.s. located on 98 4.2l in reference to installing a sun pro tach?
Old Apr 6, 2007 | 05:15 AM
JMC's Avatar
JMC
25 Year Member
There is a pink and white striped wire going into the instrument cluster. Pull the ref signal from that wire. It is in the flat white connector with 16 slots. There should be only 14 wires in the connector. 2 slots are not used. The other connector has 12 slots with 7 wires so it is not difficult to tell them apart.
JMC
Old Apr 9, 2007 | 04:52 PM
sc98f150's Avatar
tach install
thanks, but i cant locate the pink and white wire. is it going into the power distribution box in front of driver's side??
Old Apr 9, 2007 | 06:29 PM
JMC's Avatar
JMC
25 Year Member
No, it is behind the instrument cluster. Pull the cluster to access the conector.
JMC
Old Apr 10, 2007 | 03:41 PM
sc98f150's Avatar
thank you JMC. i got it installed now. as you can probably tell i dont know much about vehicles.
