02 replacement?????
Old Apr 3, 2007 | 02:16 PM
csf150's Avatar
Question 02 replacement?????
i have a 02 sensor i have to replace. the one closest to the manifold on the driver side any tips on how to do it?? i looked and it dont seem to be as easy as i hoped.
Old Apr 3, 2007 | 04:52 PM
Jordan not Mike's Avatar
You should be able to do it from underneath the truck.
Not sure if there's a better/easier way, but that's how I did mine, just take your time.
I even use common wrenches, not the special sensor-removal ones.
Old Apr 9, 2007 | 10:48 PM
rmeidlinger's Avatar
there is an easy way
If you don't have access to a lift remove tires and the plastic inner fenders.6 phillips head screw and 3 plastic retainers
you can sit under the fenders and it is as open a picture window. the nice thing is that yuou can then remove them with a 22mm or 7/8 box wrench.
it also makes it much easier to unhook the electrical connectors
I replaced both and had the tolls put away in under 45 minutes
Old Apr 9, 2007 | 10:57 PM
anyman's Avatar
Go to autozone / advance auto and rent the specialized socket. I tried everything before I broke down and rented it. It literally took my less that 5 minutes to take the 02 sensor out and replace it.
