Help oil ?
Help oil ?
I have a 99 F150 5.4 4x4 i have always used 5w30 motorcraft oil and filter guys i talk to say 5w30 is to light in summer and i should use 10w30 what to do?
my truck calls for 5w30.
If you are using 5W30 Motorcraft oil and filter, that's what the factory recommends for your engine under all operating conditions and there's no reason to use anything different. You can if you want to though but I personally prefer to follow manufacturer's recommendations.
Originally Posted by chester8420
20W50 won't hurt it. Neither will JD Plus 50. Neither will 15W40. Neither will 10W40. Neither will 10W30. Neither will 5W30.
(FWIW, Ford has rated their 5W20 Synthetic Blend to replace just about every oil weight recommended since the mid-80s. There are a few exceptions, but the F-150 is not one of them)
-Joe
Originally Posted by GIJoeCam
Ditto... Run it on canola oil if it makes you sleep better at night. Sure there are other oils that will probably work just as well, but plain ol' 5W-30 is what the factory recommends for it. Unless your buddies know something about your engine that the powertrain engineers that designed, tested, and built it overlooked, I'd suggest sticking with the OEM recommended 5W30.
-Joe
-Joe
Motorcraft 5w30 is a synthetic blend
